oil pan leak
I have an '86 d-150 pickup. it has a 360 motor. the oil pan leaks at the front and rear. do I have to lift the motor to drop the pan? any other advice on changing the gasket and lower seals is appreciated. thanx
I believe you do need to raise the motor, disconnect the drag link, remove the trans inspection cover. May also need to rotate the motor for the crank counter weights to clear the pan
