PCV ON 318 hook up question
Old Feb 9, 2010 | 01:52 PM
SPICOLIE203's Avatar
Smile PCV ON 318 hook up question
I just dropped a new 318 in my belvedere and i have an oil cap on the driver side and a breather on the passenger side. I am getting steam/ smoke out of the breather on the passenger side.
Do I need to hook one side up to the PCV port on the carb?
I thought that the PCV was just an emissions thing but with the smoke coming from the breather I am thinking maybe not.
Can anyone explain how, why , and if i need to hook up a pcv on the motor.
Thanks all
Old Feb 9, 2010 | 06:34 PM
pcv valves are good for the motor
i even have one on mine, pre emissions
do you have a heavy cam in the car?
Old Feb 10, 2010 | 08:45 AM
Not a heavy cam but a mild upgrade from stock I am also running 9.6 to 1 compression pistons. I am going to the store today to buy a PCV and hook it up.
Thanks for the help
Old Feb 10, 2010 | 09:08 AM
no problem
keep us posted
Old Feb 10, 2010 | 04:43 PM
hooked'er up and it worked like a champ. no smoke running clean, i can't wait to get it out on the road.
Thanks again
Luke
Old Nov 30, 2013 | 10:50 AM
Brian C.'s Avatar
Im having this same problem on my '68 Polara (318), has pcv valve on right valve cover & the left valve cover has a breather hose that goes to the inlet on the stock air cleaner..the engine makes enough steam to slightly choke the motor at idle so I took that hose off & the car runs fine now but makes a ton of steam out of the breather filter I put on it. Not sure on the history of my 318, can this be head gaskets? Runs good, idles good, no oil in water & vise versa but makes steam out the left valve cover. Any thoughts/ideas??????
Old Nov 30, 2013 | 12:12 PM
Is it steam or blow-by Check the PVC valve it may not be working stuck open or closed
Old Nov 30, 2013 | 12:37 PM
Brian C.'s Avatar
Pvc rattles just fine/not stuck & the white steam/smoke doesnt smell like oil & thats why Im stumped... thanks for the reply too!
Drag Pak
Nov 7, 2014 11:31 AM
Rooty
Oct 15, 2014 03:30 AM
hemi165
Mar 12, 2012 06:03 AM
67440X
Apr 1, 2011 03:21 PM
TCPMeta
Jul 15, 2007 09:23 AM
