Go Back   Mopar Forums > GENERAL > General Technical Questions
Thread Tools Display Modes
Old 08-13-2008, 01:20 PM   #1 (permalink)
Monacoman
Member
push rod removal
i have a bent push rod in my 318 its from a 66 monaco do i have to remove the heads to remove the push rods, if not how can i do it?
Monacoman is offline   Reply With Quote
Old 08-13-2008, 02:04 PM   #2 (permalink)
Monacoman
Member
K SO ROD ISNT BENT ITS BROKEN WHERE DID THE BOTTOM HALF GO???
Old 08-13-2008, 05:06 PM   #3 (permalink)
ChallengMe1973
The Mopar Kid
Ouch, grab a magnet from autozone and fish around! the only place it could of gone is down because of our friend gravity. If you cant snag it with the magnet below the camshaft, then im sorry my friend pull the oil pan and remove it because thats where it is. If you dont get it outta there, it could cause some siereous damage. This has happened to me, thankfully the rod was hanging on by a thread of metal.
ChallengMe1973 is offline   Reply With Quote
Old 08-14-2008, 04:54 AM   #4 (permalink)
Doc
MasterDebater
Doc's Avatar
Ouch x 2 !
As C-guy says .. the pan might have to come off. You don't want to have that flying around in and around the rods and crank. BUT first .. you might want to pull the intake .. if fishing-around with a magnet does not work.
Doc is offline   Reply With Quote
Old 08-14-2008, 02:35 PM   #5 (permalink)
richinny
Senior Member
a long shot, but if it's in the pan, you might try to fish a thin flex magnet through the drain plug.
richinny is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Bent Push Rods 67 GTX Do-It-yourself Section 8 11-06-2008 05:33 PM
Bemp Push Rods 67 GTX B-Body 2 07-30-2008 09:41 AM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
LinkBacks Enabled by vBSEO 3.0.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61
