stalling problem 2.5 ltr
Old 03-13-2009, 02:05 AM
does it do it only when its warmed up or when its cold too?
Old 03-13-2009, 05:47 AM
Commando's Avatar
What region are you from? There was a similiar issue from someone up in Canada a couple months ago and the problem was in the ecm or lean burn, whatever ignition module is in there. The issue is that when the temperature changes the circuit board shrinks or expands which may cause connections to come apart or come back together, so if you see a change with temperature this could be your issue.
Old 03-13-2009, 08:28 AM
FSJs from the 80 have that same problem with heat.
D5PARKER
07-01-2012 01:13 PM
twalace
06-26-2012 12:02 PM
michuy
06-16-2012 07:19 AM
Salty
12-17-2010 12:33 PM
sjparadiso
02-01-2010 03:36 PM
Quick Reply: stalling problem 2.5 ltr
