transmission oil pan inside painted
Old 10-15-2008, 06:01 PM
challenger's Avatar
i would just put it on jack as you should change your fluid after about 6000 miles anyway but the paint they use is usually baked on and shouldn't flake but if id does im almost certain it will not interfer with anything but if you dont feel comfortable just as you say sand blast it off and you will not second guess yourself --- i change my wifes 02 pt cruizer pan last year and when i changed the fluid in july i dont remember seeing any flaking ---- also welcome to the forums , hope any of this helps you
djmaster219
03-03-2014 08:02 AM
northcoasttip
09-27-2011 05:11 PM
Valcam
06-26-2009 01:51 PM
MarkyMark12345
04-10-2009 06:43 PM
dzltd02
10-28-2008 08:25 AM
Quick Reply: transmission oil pan inside painted
