Warped Heads
on
Warped Heads
Does anyone know what the rule of thumb should be when checking heads for flatness. I checked my heads and and the biggest feeler gauge i could put under is .006. Is that to much or is that exceptable.
Thats pretty good. If anything, I would talk to your local machine shop and see what they can cut. I would probably shave off .005 just to make it flatter and seal up better.
Have you checked the deck od the block?
on
