wiring
Guest
Posts: n/a
wiring
I need a 70 roadrunner ignition switch wire diagram.
for some reason, it will not turn over
it's not the starter! it turns over when i hit the relay
it's not the relay! it does even click
so don't even ask!
i don't know if it's in the switch, or if I have a loose wire? I was searching for the reverse light wire and after moving things around, no start
Please if anyone can supply a wire diagram, so I know what wires are what on the switch
thanks
Tish
so don't even ask!
thanks
Tish
