Resources This section is for books, websites, stores, etc. that you have maybe have helped you with your project(s).
1989 dodge 350 islander edition stalling problem
Old 07-23-2012, 08:48 AM
ROCKY's Avatar
I am looking for some help with a problem that the mechanics just cannot solve. the problem only happens on a hot day after about an hours worth of highway driving the van just stalls even at highway speeds. if i wait for about half an hour to an hour it will start up again and run for a short while and then stall again. i have replaced the pick up in it and done plugs and wires and the previous owner had a bunch of work done to it as well. I have had the van in the shop and they have had it idle for a hour or so just to get it up to temperature and it was working just fine. i took it camping on the weekend and drove for about 2 hours without any problems , but on the way back the temperature was about 32 degrees celcius and about a hour and a half into the trip it stalled and left me stranded for about an hour. any help would be greatly appreciated as i am getting a little frustrated.
thanks Steve
Old 07-23-2012, 11:46 AM
360 V8 with an automatic trans? Is it throttle body injected or carb?
Old 07-28-2012, 03:36 PM
ROCKY's Avatar
360 V8 Automatic with a throttle body.
Old 07-28-2012, 04:36 PM
Have you tried another computer? I'm wondering if the heat is causing it to cut out.
Old 07-28-2012, 05:45 PM
lilredex's Avatar
Was the Hall effect pick-up replacement that was installed, a new one?? 'Cause that is the symptom of a defective unit.
vorstang
06-29-2011 06:41 PM
deadkelly
Non-Mopar Tech Questions
10-17-2010 08:08 AM
prachts350
10-02-2010 04:28 PM
mystarcollectorcar.com
08-14-2010 04:10 PM
37 newbie
07-27-2010 03:52 PM
Quick Reply: 1989 dodge 350 islander edition stalling problem
