Vacuum source for heater A/C temp.control
1989 Dynasty 3.0 liter : lost the vacuum signal to shut off the heater hose supply of hot water to cabin. I believe that the signal comes from the Heater A/C temperature Control Switch ( lever arm ) on the dash.
I want to trace the vacuum signal to its origin ( I suppose at intake manifold).
Can anyone pinpoint where on the intake manifold this vacuum hose is connected?
Perhaps mine was disconnected at the intake manifold. Hope so.
I believe that the vacuum source for the interior temperature control unit originates at the vacuum brake booster as a thin black vacuum tube running from the vacuum brake booster through firewall to the interior dash temperature control unit.
If anyone knows differently , kindly advise.
stilllearning6
10-01-2014 08:04 PM
Fury IIIski
09-27-2009 07:47 AM
