3.3 L Unknown Electrical Connector
1 Attachment(s)
I have a 1990 Dynasty and have been wondering what this red connector would go to under the hood. It runs and drives fine and no electrical components fail to work. Maybe it's for something that this car does not possess (like some option that wasn't ordered). It's on the driver's side of the engine. Any ideas?
1 Attachment(s)
Not sure why that first photo didn't work.
Should have a home somewhere close.... :)
I was unable to find anything that it would plug into in the vicinity of the connector. Any ideas on what it could be coming from or going to?
Look under the Brake fluid Reservoir and see if it might be from that.????
I checked there this weekend when I was home (I'm an out of state college student). I found nothing that didn't have a connector already in it. All looks good, except for this one strange connector.
What Color are those wires? I'll try to find out what it's for.. :)
Just a thought, But it might be for the abs motor on top of the trans???? |
The next time I'm at home, I'll check to see what colors the wires are. To be honest, I'm not even sure if the car has an ABS system. As far as I was aware, that was optional equipment and wasn't standard on the 1990 Dynasty. Please correct me if I'm wrong on that.
I have not worked on those cars in years, But I'm trying to dig deep for you...:)
They might use the same harness but just not use the wiring. But I'm not sure that what this is in this case... Will see if we can figure it out by the color code of the wiring... |
I really appreciate your help with this car again! Next time I'm home, I'll check those wires and see what colors they are.
I finally got a chance to see what color wires are connected to that plug. They're both striped. One is blue and white, and the other is grey and yellow.
JR. I took a look, but was unable to find the color coding of the wires. So I'm not sure what that connector is for. Might just have to find a car and look it over to figure that one out... Best regards.
That sure is strange! Hopefully, I can find one somewhere and take a look. Thanks for all your help!
Are those wires part of the harness or spliced into something
