318 or 360 but not a 440
hey, I bought a 1977 powerwagon plow truck, the motor has been replaced and was told that it is a 440 but, the 440 has the distributor in the front, right???
And the 318 and 360 are in the back by the firewall, which is what I have in this truck. But how can I tell if it's a 318 or 360??
thanks
thanks
It's also stamped into the block right below the front of the driver's side head. Just scraper 'er clean, and read the numbers. 318, 360, will be in that number string in the first few numbers.
440's are a "raised big block" and like all BB engines, yes, has the distributor in the front.
You could post the VIN but that will only tell you what the truck came with for a motor. Wouldn't really help if someone swapped it out for another.
Although, you can post the numbers cast into the block and we can tell you production year of that block. They should also be on the passenger side of the block.
LOOK on the FRONT driver's side of the block directly below the head/ block parting line. Scrape it clean, there's a number string right there.
The CID of the engine is stamped right there in the first few numbers.
Should take you 1 minute, tops.
on
Nobody wants to listen, and you do NOT even have to crawl under the truck.
68camperspecial
04-14-2009 05:28 AM
