318 Motor !!!!!!! Bore Question
How much Bore is to much for the block to handle on a 74 318 ?????
I wouldn't bore it any more than necessary to clean up the bore. Should be able to go .060" any more than that you would need to sonic check the bores for thickness.
Would also need custom pistons for anything over .060" |
Originally Posted by TVLynn
(Post 91433)
Pulled motor and had checked.....It already 60 over.... He is checking to see if its possible to just Hone the block....If not , Im looking for a good 360 Block.........
