392 Spring Retainer Hitting Rocker arm
Old 09-14-2022, 04:15 PM
Dansic's Avatar
As my title suggests, my 392 with a cam swap has a rocker arm clearance problem. When the valve is all the way closed, the rocker arm body is hitting the spring retainer instead of the rocker tip on the stem. Its a TSP cam kit wtih 585 lift, PAC 1232x springs and the reccomended r311 retainers. Using johnson 2326 lifters and TSP supplied pushrods. How should I go about fixing this? Its a pretty servere contact issue. The damn rocker tip cant even touch the valve stem when the valve is closed. When I had the stock retainers on these springs, I didnt notice this issue. But I dont th8nk the stock retainers can survive 450 lbs.
Old 09-15-2022, 07:40 AM
Looks to me like the shaft needs to be shimmed and will need longer push rods?
Iowan (09-15-2022)
Old 09-15-2022, 05:38 PM
Drag Pak's Avatar
What Bob said, and that retainer looks wrong ? My Drag Pak 392 was 0.605 Int lift and had 0.10<0.14 of clearance at the (chamfered edge) retainer! Try looking at what Comp Cams has to offer?
Iowan (09-15-2022)
Old 09-15-2022, 06:06 PM
Improper torque sequence on the rocker arm assembly?
Gorts 5th
01-27-2013 06:00 AM
SPICOLIE203
11-23-2011 05:59 PM
SPICOLIE203
09-25-2011 08:02 PM
DUST360
10-11-2009 09:54 AM
Commando
01-07-2009 07:20 AM
Quick Reply: 392 Spring Retainer Hitting Rocker arm
