87 dakota motor swap
Old 08-14-2013, 06:44 AM
mscarchuk's Avatar
Im doing a v6 to v8 motor swap in my 87 dakota. Came stock with a 3.9 and 3 speed auto tranny. Putting in a mild built 318 la series and just wondering what kind of electrical and computer related things i will need. Key is going basic overall just have never done a swap before and want to know a whole list of what im gonna need. I also plan on having a msd box in it also.
Old 08-14-2013, 09:16 AM
slade's Avatar
is your truck fuel injected? my 93 has a la carbed 318. i used a ready to run distributor i got rid of all the co
puter and wiring harness and im usi.g a 1 wire alt to clean it up even more.
theres no need to use the mopar orange ignition box or anything from the old harness the distributor does it all for you
you do how ever have to wire the distributor in i wired mine to the fuse box. this should get hou started. check your clearence on my 93 i need a e-fan
Old 08-14-2013, 09:47 AM
mscarchuk's Avatar
The truck is carb from the factory in 1987
Old 08-14-2013, 09:49 AM
slade's Avatar
ok so this should be a relatily easy swap for you to
Old 08-14-2013, 10:07 AM
A 3.9 is just a 318 with 2 cyl cut off so it should be easy swap. If you don't have a motor yet ? I would put a Magnaum 318 in it..
Old 08-14-2013, 01:17 PM
I'd look for a Magnum 360. The tranny behind the 3.9 won't hold up at all to a stock 318 yet alone a mild 318.
Old 08-14-2013, 01:18 PM
mscarchuk's Avatar
Yes i know i have a a833 4 speed im putting behind it
Old 08-14-2013, 01:42 PM
Mr.4spd's Avatar
Sounds like it's gonna be a fun truck. 2WD?
Old 08-15-2013, 06:10 AM
mscarchuk's Avatar
Yes it is and then once i gey it all back on the road gonna stroke a 360 to a 408 and supercharge it
Old 08-15-2013, 07:24 AM
slade's Avatar
whats done to the 318
Cory Riopelle
11-22-2013 12:23 PM
jmcarp
05-15-2013 07:39 AM
THUMPER
02-15-2012 05:21 PM
dodgenut7
06-10-2011 03:47 AM
gofastbobby
10-29-2010 09:53 AM
Quick Reply: 87 dakota motor swap
