Air Cleaner Upgrade?
Hi,
Does anyone know where I can find a upgraded Air Cleaner assembly for a 74 360 2bbl B Body Charger? I'm only using the PCV, Brake Booster & Dizzy for the emissions.
Most of them will fit... Sometimes you might need an adapter to fit the air horn to air filter assembly..If you still want to run the breather to the Air Cleaner... You can Buy one of these..... http://www.jegs.com/p/Spectre/Spectr...42109/10002/-1 ... And install it... I think the Moroso's still have the knockout to use them.
You could... But it dose not help with the evacuation of the crankcase and its fumes without having it hooked up... You could also change it over to a chrome open breather in that case also. You could also get an air cleaner that has the breather hook up, or the capability of adding it.... Check out the Moroso Air cleaners for further understanding...
jobberone
09-03-2009 09:34 AM
