clear rad hose
iam wanting to put a coolant filter and a clear rad hose on my 01 dak V6. know of any?
Why???? they do make a clear thermostat housing so you can see the stat.... I have never heard of a filter or a clear hose unless it was for a milking machine:laugh::laugh:... You crack me up Moe...cash<you:broke:<me...Bill
You could look into Porous Ceramic Membrane, good to 1000 degrees C. It will be quite large, maybe 12 inch diameter would do.
Hose is a problem as I've only seen it up to 150, maybe 180 degrees F. All the hose we use on steamers is not clear. You'll need a Booster pump as the stock one won't generate enough pressure to push through the additional piping and the filter. I would suggest a Commercial Dishwasher pump from a Hobart K series with metal housing, most of the Jackson, Champion and MDL's are using plastic housings now which probably won't hold up, stay away from Jet Tech they are junk. I think it is doable and would fit nicely in the back seat or trunk if you want to maintain passenger space. |
(Post 119356)
Hose is a problem as I've only seen it up to 150, maybe 180 degrees F. All the hose we use on steamers is not clear. You'll need a Booster pump as the stock one won't generate enough pressure to push through the additional piping and the filter. I would suggest a Commercial Dishwasher pump from a Hobart K series with metal housing, most of the Jackson, Champion and MDL's are using plastic housings now which probably won't hold up, stay away from Jet Tech they are junk. I think it is doable and would fit nicely in the back seat or trunk if you want to maintain passenger space. LMFAO...Looks like your on your own on this one Moe....Bill |
I think you need a clear radiator to got with all that......
:duck: |
Originally Posted by pro-tech
(Post 119354)
Hey Bill, I sell milking machines but have never heard of a cow giving milk that hot!!! It would be self pasteurized and save a step at the dairy.... The hoses we use would not stand the pressures or the temps!!! Good idea,,, And that is thinking out of the box for sure!!! |
Originally Posted by MReeves
(Post 119373)
:doh:
most of the time you cats DO know what you are talking BUT. there IS clear rad hose. i found some. OK its fine to tease me. but SOMETIMES i do what iam talking about.
Originally Posted by moe7404
(Post 119391)
poking fun at me is fine. on a radio control site that i go to we poke fun at one guy about not wearing pants. it gets very funny. i made up a saying about me being a red neck.
"I am the west side red neck. Iam old, cantankerous, bias, prejudice, and I dont suffer fools or idiots. Get over it" got to go i need a nap. |
