Correct Torque Setting for Intake Manifold BOLTS ON 6.4L ?
Anyone know the propper torque setting for intake manifold bolts on the 6.4 engine (2011 Challenger 392)? I posted this question elsewhere, & I get replies (guesses) from some well-meaning guys ranging from 105 in.lbs.... to 210 in. lbs. http://www.challengertalk.com/forums...cratchhead.gif
Maybe someone who has a Service Manual can check & let me know for sure. Would appreciate it! Thanks! |
Here is one answer. At 106 lb.in. It isn't very much more than "Careful or you'll do harm".
http://www.justanswer.com/dodge/4ngm...-6-1-hemi.html |
Originally Posted by Drag Pak
(Post 128266)
Thanks, but that's for the 6.1. The 6.4 is a different intake...spec is probably different. |
Originally Posted by JETBLU
(Post 128267)
12 NM or 9 Ft Lbs.... That from ProDemand As of 5 min ago...
Bob, that sounds just like 106 lb.in, lol.
Hahahahahahaha.... I did not go out that far..
Thanks for the conversion....lol |
OK, Cool! Thanks guys!
Don't try to do it with your ft' lbs torque wrench USE an in" lbs wrench
I'm assuming Bob's going by the "manuals" nomiclature and he's right on - 9 ft. lbs. but 10 won't hurt either.
Yes...That is rite out of the Manual... No B.S.
