Intake manifold screw-up
Old 03-25-2012, 02:33 PM
crwchf16's Avatar
Exclamation Intake manifold screw-up
I don't know exactly I what was thinking other than trying to remove the corrosion from Old Red's intake. I brought the manifold to a local machine shop and had it shot-peened clean. (I'm already kicking myself for even thinking of this to begin with. ) Unfortunately their cleaning process after the peening was non-existent and now I'm wondering how to ensure I've gotten all the steel shot out of the inner passages. I've blown the manifold out with air a number of times, flushed it out with water, then used compressed air again to dry it and hopefully remove whatever may be left inside.
Considering the damage possible if even one little steel bead gets into the engine I'm being as paranoid about this as I can be. Anyone got any other tips for bailing me out of this screw-up?
Old 03-25-2012, 05:11 PM
blue 68 gts's Avatar
Keep blowing it out. Thats about it.
Old 03-25-2012, 06:19 PM
fivepoint's Avatar
In addition to blowing it out, use a plastic mallet and tap all around the manifold to loosen up any lodged in pieces.
Old 03-25-2012, 06:58 PM
PK1
PK1's Avatar
You aren't the first person to do this. It will be fine..
I would grab some over-sized boiler brushes and run the passages. They'll come out.
Old 04-17-2012, 05:48 AM
crwchf16's Avatar
You guys may be relieved to know )as I was) that I finally got all the crap out of the intake. As proof, I started the engine and it's been running for some time with no intake problems. Thanks for the advice!
Old 04-17-2012, 03:48 PM
Thumbs up
Nice job!
rookie440
09-15-2013 06:39 AM
ttoaster
04-28-2013 07:41 PM
4porte3
03-28-2012 04:17 AM
1966DartConvertible
08-24-2010 11:13 AM
M1 Manifold
05-21-2009 02:23 PM
Quick Reply: Intake manifold screw-up
