Lifters
So if you havnt been following Ive had my top end apart for about a month now in my garage. Ive been coating it with wd40 and dumping a bottle of motor oil down the galley and in the lifters to keep if fresh and lubed. My question is, should I give the lifters another oil bath overnight, like during initial assembly of the motor or should they still be oiled up from before? (Hydro lifters)
Thanks |
I'm no engine builder by any means but I can't see it hurting. I say do it.
It won't hurt but it's not needed. The other issue is that each lifter has worn on the cam lobe that it is on now. That's why I wouldn't pull them out.
