need some help
need some help
i have a 67 valiant witht the slant 6. i need some help deciding what to do about the exhaust pipe. at the moment it doesn't have a muffler and is dumped in front of the rear axle. i was wanting to run it out in front of the rear tire, but due to the parking brake cable running down the drivers side i was thinking of the passenger side. would this be acceptible or should i try to find the rear pipe that goes over the axle and run it out under the rear bumper?
i plan on keeping most of the stock exhaust. the issue i have now is that the exhaust pipe ends just under the back seat. and i can't find the rear half of the pipe that goes over the axle. i was thinking as a temp fix if it was possible to run it out the pass side without any major issues. i apperciate your reply on this as i can't seem to figure out how to do this.
oh ok for some reason i was thingk you ment up by the front tire. it was a long day at work. but i think i have a plan and will post pics of how i did it as soon as i get it done.
