Slant 6 in 1958 D100??? Help
Old 03-01-2013, 05:08 AM
slant6's Avatar
Has anyone replaced a flat head 6 with a slant 6 in a 1958 d100? What problems can I expect? Thanks, Lew
Old 03-01-2013, 08:40 AM
You'll need to swap transmissions, make up some custom motor mounts, transmission mount/cross member, drive shaft, radiator inlet/outlet may be different and wiring (should be pretty simple though).
If you are going to be swapping to a slant 6, swapping in a small block V8 would probably be the same amount of work and you'll gain more power.
Old 03-02-2013, 05:42 AM
slant6's Avatar
WOW!!
Thanks for the help! I already have a rebuilt slant6 with a 4 spd tranny. I will wait until a find a d100 with a bad slant 6. Thanks again, Lew
Old 03-02-2013, 06:55 AM
That is the easiest and cheapest thing to do with that /6. If the tail house length is short, you could also throw that setup into an A-body car with a /6 and have some fun too.
Aesthetikz
06-25-2014 06:30 PM
aepowell
10-10-2013 10:52 PM
rapidtransitrick
04-21-2013 03:44 AM
cmetzbower
08-04-2012 07:44 PM
cmetzbower
10-11-2010 12:27 AM
Quick Reply: Slant 6 in 1958 D100??? Help
