Timing chain tensioner
Old 01-08-2012, 12:33 PM
spike's Avatar
Hi, thanks for welcoming me.
I ran this mopar timing chain tensioner/cam thrust plate for about 2000 miles.
A .007" groove wore in the cam thrust location.
After further inspection I discovered that this part is stamped and the metal is soft.
The original style thrust plates without the tensioner are hardened and ground flat.
Has any one else run into this problem?
I dont think I would use one again.
Old 01-08-2012, 03:49 PM
What car ? engine are we talking about ???
Old 01-08-2012, 04:44 PM
That's the purpose of it. I should wear some as time goes by. The factory thrust plate would have a wear pattern on it also. I have heard good and bad about those tensioners. I would use a factory type thrust plate. Your distributor gear could be worn also.
Old 01-08-2012, 05:47 PM
spike's Avatar
It was in my dart with a stroked 340.
I have seen wear marks before, but never a worn groove.
The cam and gear were new.
I ran a file across it and it cut pretty easy. The file would not cut the original style thrust plate.
Old 01-08-2012, 05:51 PM
Get rid of it.
Old 01-08-2012, 05:53 PM
spike's Avatar
Get rid of it.
I sure will!
Old 01-08-2012, 07:05 PM
I sure will!
You can get a new thrust plate at Mancini Racing.
Old 01-08-2012, 07:17 PM
PK1
PK1's Avatar
If memory serves me correctly there was a TSB about these being used to quiet timing chain noise or rattle when redoing the chain in 5.2 and 5.9 magnums. I see them on Jeeps, Rams etc... I may have one in the shop.
I would dump yours too. It sounds like an aftermarket reproduction and not well made. I see color transfer from heat when taking these off but never a groove.
Gorts 5th
12-19-2012 04:52 PM
eris2krat
07-30-2012 05:19 AM
teedeej340
12-01-2010 06:16 PM
roadwarrior86
10-11-2010 11:40 PM
recondotexas
04-03-2010 03:44 PM
Quick Reply: Timing chain tensioner
