What Is this hole for?
Hi guys. I would like to know what Is the function of this hole located in the head of the last rear cylinder? Thank you.
https://cimg5.ibsrv.net/gimg/moparfo...aac8dc427c.jpg |
When the head is mounted to the engine block. If i recall, you use that plugged hole to insert a rod down in to find "TDC" Top Dead Center of the piston...
Don't know why they used the number 6 cylinder instead of the number one cylinder? But guess it doesn't matter... result should turn out the same... |
(Post 162661)
