1986 727trans leaking lots fluid
my 1986 ram charger 4wd tranny leaks badly.Leaked 1 month after purchase.Installed new turque converter seal.Not the problem.So replaced pump with new nos ,converter, and installed a rebuild kit,but did not mess with the valve body.Also installed a new 3 row radiator[had all the parts in my warehouse already to go]Will add from day 1,the tranny took a long time to shift thru the gears till it reached temp.Then it ran great all day.That never changed even after I installed a rebuild kit in it.Fluid had great color til the day it poured out all over my driveway.It was almost black.It was never in 4 wd during this time.The owner had differential rebuilt by a pro,but he rebuilt the tranny[found all the receipts].Any suggestions?
Did you ever ajust the bands?
Or check the seals at the shift linkage or pan gasket? |
checked all 3 or those things.Especially the seal around the shift linkage.That was leaking the day I bought it.1st item I replaced on tranny
Pick up this book....
Buy a good Overhaul kit from Red and Arts / Cope Trans / A&A trans / read the book pick up a few tools and do it yourself.... Keep us posted.. You will do just fine... Read the book twice before starting... |
Just got the rebuild kit.Going to replace the valve body to the original spec.Of cource its now raining everyday when its not freezing cold every day.thanks
Originally Posted by 360 mafia
(Post 152836)
Cheers |
