727 Trans wont go into gear
Old 04-16-2017, 12:36 PM
JPR56's Avatar
Hey Guys
I'm new to this forum and looking for your help
I just got a 1936 Plymouth P1 with a 1968 Charger 383 Magnum bored 30 0ver with a mild cam and a 727 trans. Took it out the other day to a friends and when I went to start it it would not go into gear. towed it home and adjusted the linkage but now only have Park, Reverse, Neutral and 3rd gear it kind of whines in first and second but will not move. Oil is fine.
Any suggestions.
Old 04-17-2017, 09:38 AM
Drag Pak's Avatar
The front and rear bands are so worn/out of adjustment they will not hold? Drop the pan and check. The oil pump is worn out? Either way, it sounds like a major!
Old 04-17-2017, 05:51 PM
I agree... Sounds like the T.V. Linkage was out of adjustment and took out the clutch's...
Not a good sign.. Sounds like Overhaul time...
Welcome to the site.... Keep us posted on how you turn out...
Old 04-18-2017, 06:10 PM
JPR56's Avatar
727 trans wont go into gear
Awesome, Thanks for the replies, it exactly what you said. Total rebuild
Thanks for the help
Awesome site
Jim
Old 04-19-2017, 06:11 PM
Keep us posted on how it works after you get it all fixed....
Jeff Olenski
09-05-2016 05:03 PM
sm73charger
09-10-2015 10:03 AM
AllyRat31
01-27-2015 09:38 AM
krublee
01-02-2011 11:02 AM
staledog
10-13-2010 08:10 PM
Quick Reply: 727 Trans wont go into gear
