a518 on 85 360 la
Old 01-13-2013, 03:02 PM
85dodgeram350's Avatar
a518 on 85 360 la
i have a 92 a518 in a 85 dodge ram and its bolted behind a 360 the tranny came out of a d150 with non lockup converter and the old 727 kickdown linkage and it has a holley street avenger 670 and i feel like it doesnt down shift easy enuff if i slow down then hit the gas it just doesnt down shift unless it punch the gas how should i adjust the kickdown so it down shifts earlier and its a rod style not cable thanks ahead of time advise much appreciated
Old 01-13-2013, 03:10 PM
bigblock's Avatar
You cant adjust the linkage to fix that. A shift kit may have what you need. Consult with Summit Racing or Jegs.
Old 01-13-2013, 05:10 PM
IT is adjustable.. Either at the trans or at the carb..
Old 01-14-2013, 07:50 PM
Ok thanks and I know it's adjustable I didn't know witch way to go with it
Old 01-14-2013, 08:19 PM
Gorts 5th's Avatar
Smile
i put a kit in mine but the linkage should be adjusted to the rear
the arm pushes back to increase trany fluid pressure. should cause a kick down but if you want a more street/strip feel then a shift improvement kit is the ticket i used a ATC reprogramming shift improvement kit.
Old 11-24-2014, 06:57 AM
stoffy's Avatar
la 360 to a518
hi did you do this swap ? if so what did you do about converter weights flexplate ect. ?
Old 01-04-2015, 01:16 PM
Gorts 5th's Avatar
Smile
You have to use the 360 tork convertr .... lock up is available check out my post big time swap the kick down govner.is adjusted by spring the shift improvment kit contains all the parts check out PACT.COM They have all parts needed
Old 01-04-2015, 02:04 PM
moe7404's Avatar
the best place to get info. have known them since the late 60s. if they cant answer your Q no one can. http://www.areds.com/
orangesteve
27
04-08-2013 02:59 AM
maca
01-20-2013 02:49 AM
maca
18
01-14-2013 04:24 AM
85dodgeram350
10-31-2012 05:38 PM
erwatt
02-12-2009 03:45 PM
Quick Reply: a518 on 85 360 la
