front clutch destroyed after 15 pass
hello ... anyone know why my front clutch everytime is destroyed after 15 pass ?? 727 is full manual with no low band apply smr valvebodie
thanks
Raffaele
thanks
Raffaele
Drum Got drilled 0.050 for more pressure?
Blown out seal?
Wrong Direct drum piston?
Raffa...If you have to much more problems... Have you talked to John Cope at Cope Racing Trans? I think he can help get you fixed up.
That's way to much failure there my friend !!!!
Blown out seal?
Hi Bob ... everything is checked ...i have buy all parts from SMR transmission :
front billet drum
5 gear planetary
billet piston
billet rod
red alto clutch
smr AA valvebodie full manual reverse pattern
i dont have speaked with John Cope because i dont have buy the parts from he
SMR told me that car is too powerful for this transmission
Oh Boy.... If that the case..... Then it looks like it might be time to convert over to the G.M. T.H.400 or the Super Glide, Bruno's, B&J.
I did not think you were up in that H.P. range yet? But when you start getting near that 900 foot pounds of torq. (FPOT)... Then things start getting iffy...
I'm not 100% sure this will fix the problem.... But ask SMR if there is a way to get somemore line pressure to the front drum?
Speaking of line pressure, Ask SMR or A&A what the pressure should be and get a reading from the trans port?
If all is well there... Then I would have to agree that the motor is just over powering the trans.....
Hope you had a great time here in the USA.... Looks like you and everyone had a great time.... Sorry I could not meet you at NHRA Pomona.
I Hope John Cope Got your trans problem fixed, and no more burning up clutch's in the trans.
On the front suspension.... It you have a Sway bar in the front??? Disconnect it and let the front end travel natural....
A 1.40 60' should get you in the 9.90's or a little better...
Good Luck....
Good Luck....
Good Luck....
Good Luck....
ThomasNieman710
31
07-11-2013 05:00 AM
NMCA Jeff
shopHEMI.com NMCA's LATE MODEL HEMI SHOOTOUT - 5-7 JUNE 2009
04-21-2009 11:59 AM
