Gears change nightmare
I'm doing a gears change on my '74 fury but is starting to be a real nightmare!
According to the differential cover bolt pattern my axle is an 8.25 but I'm starting to think that maybe isn't due to so much problems
The stock gears were 2.83 (i think...) and the new gears are 3.55, the new pinion and gear are a kit sold by Richmond Gear Excel and the installation kit is a Motive Gear super kit.
The pinion and gear are successfully installed but now I've a problem with my carrier bearings, apparently the new bearings doesn't fit in my axle housing (see second image attached), I checked the list parts of the installation kit and everything is correct, the bearings part numbers are correct so I don't know why them doesn't fit
The second problem is that one of the adjusters in my axle is broken (see third attached image), I mean, when I disassembled the unit it fell broken in my hand. Is it easy to find? can I buy one or will be needed to buy a pair?
Send pictures of your wife!
Chrysler 8.25" Axle Parts, Gears, and Upgrades
Axle Specifications:
Ring Gear Diameter: 8.250
Diff Cover Bolts: 10
Ring Gear Bolts: 10
Axle Spline Count: 27 / 29
Axle Shaft Style: C-Clip
Pinion Diameter: --
Pinion Splines: --
Pinion Support: No
Carrier Breaks: 2.47* / 2.56
*2.54 w/ e-locker
Dropout Carrier: No
Torque Specifications:
Pinion Preload New: 12 to 15 in-lbs
Pinion Preload Reused: 6 to 8 in-lbs
Ring Gear Backlash: .006" to .010"
Ring Gear Bolt Torque: 55 ft-lbs
Carrier Bearing Caps: 60 ft-lbs
Popular Applications:
Dodge Charger 1968 - 1975 Rear
Dodge Dakota 1987 - 2004 Rear
Dodge Durango 1998 - 2004 Rear
Dodge Ram 1500 1994 - 2004 Rear
Dodge Ram 2500 1997 - 2001 Rear
Jeep Grand Cherokee 2005 - 2010 Rear
Jeep XJ Cherokee 1991 - 2001 Rear
Axle Images:
Axle Details
The Chrysler 8.25" axle is found in many Dodge and Jeep vehicles and comes in several different configurations. The 2005 and new Chrysler 8.25" axle features larger 29 spline axle shafts and uses metric ring gear bolts. All other models have 27 spline axle shafts. The easiest way to identify the axle is to check for 10 cover bolts, an oval shaped cover, and a fill plug just below the centerline. You might also be able to find the ID tag wrapped around the passenger side axle tube with the axle ID and gear ratio listed on it.
Ring Gear Bolts: 10
Pinion Diameter: --
Pinion Splines: --
Pinion Support: No
*2.54 w/ e-locker
Dropout Carrier: No
Axle Images:
Axle Details
"My wife yes, my dog maybe, my mopar never!"
Just got me wondering!
You been spending way too much time over on "Yellow Bullet" Getting eat'en.....
Jose>>>> Might even check with Performance Gear....
http://performance-gearing.com/
I finished this job the past week, my rear end is a chrysler 8.25 but the real problem was into the installation kit I bought
If someone is planning to do this job be careful and stay away of this kit: https://www.summitracing.com/int/par...rskt/overview/
Both carrier bearings and inner pinion bearing are wrong for chrysler 8.25, don't waste your money!
The excel pinion and ring works great, the car response is a LOT better but I'm still a bit disappointed, my car isn't still burning rubber launching at wot in first gear
How did that go so wrong? Wow... That blows....
