Info for changing clutch
on
I have a 1971 barracuda cloned to a 440 6-pack 4 speed dana (354posi) car. Has 833 trans. Anyone have any info on how to change and the best recommendations on what to use
Never done one before.
THANKS
THANKS
Drain fluid, remove speedo cable, shift handle, driveshaft, clutch fork, SUPPORT ENGINE and remove transmission.
Drop dust shield, blow out and don't inhale, mark clutch to flywheel orientation for same location install, loosen 6 clutch bolts 1-2 turns each at a time to release spring pressure and not bend flange, out she comes.
At this point careful inspection of flywheel is critical, removal for resurface grinding is probably a good idea with the big engine torque.
Just put a Borg and Beck in my son's truck, he has a Diaphragm in his car and I'm liking the ones they have for Mopars now.
To add to the above, factory exhaust are a bitch which you did not mention. You'll have to drop at least part of the exhaust, depending on "what you have
Inspect the pilot bushing carefully
You need a GOOD alignment tool. Getting the new one lined up CAN be exasperating, because simply, many alignment tools are not accurate enough. Those of us "lucky" enough to have broken an input pinion have an alignment tool, LOL
To work around this, be careful to get the new disc centered with the tool. Look at it carefully, "wiggle" it to test for best center
In some cases, you might have to actually loosen the PP until you get the disc engaged with the gearbox.
One thing that helped me was to put the box into reverse and any forward gear. This locks the transmission up so that when you wiggle the box, the splines move and help you engage them
A long bolt into (I think?) bottom right bell can act as a pilot to slide the heavy 'ol thang in there
I used to pull mine out of my 69 RR which is a long story, with no more than "tall" front jackstands and a big floor jack
Last, VERY important to have a FACTORY service manual. Not a Haynes or Chiltons. You can download there here
http://www.forabodiesonly.com/mopar/...p?p=1970088617
and more manuals and info here
I think for 71 you have to get the 71 Plymouth manual. One of the 71 manuals is "body only" IE not chassis
bstiles88
08-06-2009 06:02 PM
