neutral safety/ reverse switch
Old 03-04-2013, 04:27 AM
69Ronrunner's Avatar
Dose any one know if a three prong neutral safety /reverse switch is the same size or can replace a single prong neutral safety switch in a 727 torqueflite?
Can a 69 wiper be put on a 68 detent leaver to make the 3 prong switch work properly for reverse lights??
Old 03-04-2013, 07:44 PM
jacilynn_s's Avatar
Will it fit in the case. Yes. Will it work? No. The shifter arm on the valve body is slightly different and wont touch the switch.
Old 03-04-2013, 09:14 PM
I've been told that the 3 terminal switch will replace the 1 terminal switch for NSS, but will not work for reverse lights. Have not actually done this.
Old 03-04-2013, 09:58 PM
Moparod's Avatar
The single terminal NSS went bad on the 727 in my '68 Charger and I swapped it with a 3 terminal, worked just fine. The 68 backup light switch is mounted to the column- mine had a column shift, I'm not sure about the '69. If I remember right you use the center terminal on the 3 prong.
Arbiter343GS
10-31-2011 08:44 AM
Aaron.Albrecht
07-30-2011 10:24 AM
Derek77PW
07-16-2011 08:33 AM
Dave MoorePower
08-11-2008 05:59 AM
hemihead
03-18-2008 03:23 PM
Quick Reply: neutral safety/ reverse switch
