Which oil for 727 Torqueflite?
Old 07-15-2019, 07:08 AM
Scamp72's Avatar
I have a 72 Plymouth, Torqueflite 727 automatic trans that needs an oil change. I see lots of conflicting info on here as to what to use, so I apologize if this is redundant with other threads.
Manual says Dexron.
Some say ATF +4 is a better quality replacement.
Thoughts?
Old 07-15-2019, 09:13 AM
Drag Pak's Avatar
Manual says Dexron.
Thoughts?
Unless it is a new build, you should probably just stick with what is already in it.
My transmission builder "probably the best in the SuperStock / Stock world" says Type "F" or Dexron.
Old 07-15-2019, 09:27 AM
I agree, I use type F.
Old 07-15-2019, 11:00 AM
Scamp72's Avatar
Thanks so much.
Old 07-15-2019, 05:32 PM
I agree!!!
Old 07-21-2019, 09:19 AM
Dex III or Type F.
Old 12-08-2021, 04:20 AM
JackV's Avatar
Type F is the best for me. I also use transmission fluid, the 6-speed automatic transmission 1500 Dodge RAM only use ATF+4 which protects from overheating. Here you can read about it https://davesoilchange.com/transmiss...odge-ram-1500/ .It also protects against wear and tear of the gearbox, and makes it easier to use, it is an excellent replacement for conventional oil.
sendust
08-09-2019 06:01 PM
Fast4door
01-28-2014 08:21 PM
BruceB
09-01-2013 11:48 AM
Blownvh
04-04-2010 09:14 PM
sirus444
07-05-2009 09:17 PM
Quick Reply: Which oil for 727 Torqueflite?
