ABS on 1991 Chrysler Imperial
Old 08-19-2015, 12:53 PM
lady blue's Avatar
Finally found a affordable ABS unit for my 1991 Chrysler Imperial. I had experience loss of braking several times since the ABS trouble light came on in spring 2008. Been driving her with just manual brakes no assist. I was looking for parts for my Dad's 84 Caprice. Ran across a place that bought out all the MOPAR parts from many Dealers & parts stores. They had several listings for ABS units. I sent my Vin & got a new old stock for $250. It was cheaper & easier than the change over to Vacuum assit. I originally had a plan to convert along with other Electrical issues, I had started to solve each one. New PCM solved the over charging of battery, Found a hole in Coolant over flow sender. Super Glued that. Many more electrical problem that all seemed to be a Bad ground or other issues that Chrysler recalled? Apparently m Chrysler was never fixed? I contacted a Dealer service department to help me resolve problems? He said that no open recalls, Or tech bulletins? Here is the most Stupid thing I have heard from a Service Manager. He said his mechanics do not have the Tools or Knowledge to repair a 25 year old car? I heard the same from GM about my Truck? No mechanics know how to fix a 2004 SSR? I am losing all confidence in American Manufactures. This Brake problem look similar to my ABS on SSR. Too much Heat, Moisture, Bad corroded grounds lack of a good design to work for longer than the warranty period. See my ABS picture when I disassembled it.
Attached Thumbnails ABS on 1991 Chrysler Imperial-1991-chrysler-imperial.jpg   ABS on 1991 Chrysler Imperial-chrysler-abs.jpg   ABS on 1991 Chrysler Imperial-12-4108-abs.jpg   ABS on 1991 Chrysler Imperial-abs-chrysler.jpg   ABS on 1991 Chrysler Imperial-rear-chrysler.jpg
lady blue
08-20-2015 07:31 PM
Brian Grosshans
08-18-2013 05:33 PM
68satellite
08-03-2009 09:46 AM
scotts74birds
06-14-2009 10:43 PM
StanH
12-15-2008 08:35 PM
Quick Reply: ABS on 1991 Chrysler Imperial
