Ball joint replacement 06 Caravan
Hi folks. I'm going to change ball joints, tie rod ends and sway bars on my 06 caravan. I found a kit on line and wonder if the ball joints can be pressed out of the control arms? If anyone has experience on a Caravan, your input will be greatly appreciated. Thank you.
Tim |
nothing... crazy.... yes its pressed....:)
Thanks!! I didn't know if they were fused like my 99 Plymouth Breeze was. Had to replace the control arms too.
