Converting over to power breaks
Old 03-20-2017, 08:55 PM
Jim Albert's Avatar
I'm looking to convert manual brakes to power brakes do I need new brake lines? I've already converted the front disc brakes and I also want to convert the back to disc brakes. I have an 8 3/4 posi rear, all wheels are small bolt pattern. I was also wondering if someone can post a link to a brake system that I can use for a 1970 Dodge Dart It had a six cylinder and that has been changed to a 318. Thanks guys. oh also i have an adjustable portion valve is that ok to use? Or do I need an original.
Old 03-22-2017, 08:03 AM
Welcome to the site....
SSBC. Might help on the brake conversion.>>> http://ssbrakes.com/
Check the Vendor Directory up at the top of the page also for some help on the parts..
As for the 70 Conversion... Find a doner car like a 73 Dart or Scamp or Duster and pull all the hardware from it to change over..
Just my thoughts....
Old 03-22-2017, 11:30 PM
The small bolt pattern will limit your options most convert to the 4 1/2" pattern Brake lines & prop valve should be fine as long as they are not rusty..+ If you already have a 8 3/4 you should ??? convert to the 10 X 2.5 drums the smaller 9" drums are getting impossible to find which work Great. I would not put disks on unless you have money to burn. Can be better spent in other areas
Old 03-25-2017, 08:07 PM
Jim Albert's Avatar
Thank you. :)
So the 10" x 2.5 drum will fit the small bolt pattern? Do you know where I can buy those drums? If you do can ya send me the link for them? That would be so awesome. Thank you for your help. JIM ...... The small bolt pattern will limit your options most convert to the 4 1/2" pattern Brake lines & prop valve should be fine as long as they are not rusty..+ If you already have a 8 3/4 you should ??? convert to the 10 X 2.5 drums the smaller 9" drums are getting impossible to find which work Great. I would not put disks on unless you have money to burn. Can be better spent in other areas[/QUOTE]
Old 03-30-2017, 12:26 PM
I meant 10" drums if you upgrade to the 4 1/2 pattern
Old 03-30-2017, 12:30 PM
Welcome to the site........
Leem
02-10-2011 05:07 PM
fury_19
07-16-2009 08:00 AM
tish
10-01-2008 01:57 PM
chrisd
04-15-2008 05:55 PM
theaspenator
01-30-2008 06:30 PM
Quick Reply: Converting over to power breaks
