front right sag on '67 Belvedere
Old 06-17-2015, 10:46 PM
celt69's Avatar
Noticed today while chasing a small water leak that the passenger front was sitting a little low compared to the driver's side. I made a snap decision to crank up the torsion bar (clockwise) and seems to have levelled things out but hard to tell in my small garage (go for a drive tomorrow). I measured as per service manual and the passenger side indeed now sits higher than the driver yet measuring from bottom of fender to floor through the centre of the wheel says the passenger front still sits approx. 1/2 inch lower than the driver side. Never had a torsion bar car before so I understand I may have impacted alignment (not too worried as tires need to be replaced - 14" for 15" to do a front disc conversion this winter).
Thoughts on why I may still have some sag here, worn out torsion bar? Thanks in advance for my daily dose of advise! Seems I drive the car an hour and then spend a day repairing all the gremlins that reveal themselves...still looking for the water drip
Old 06-18-2015, 10:30 AM
moe7404's Avatar
what you have is the heater valve leeking rusting out the torsion bar support. it will bang the ground soon. the fix is remove the heater valve and get an aftermarket one OUTSIDE the intereir. and fix the frame.
Old 06-18-2015, 12:09 PM
celt69's Avatar
No rust on the frame or torsion bar support at all Moe, car has probably not had a heater in it for 30 plus years. No rust underneath the car at all (re-purposed ex-drag car).
Old 06-18-2015, 03:53 PM
moe7404's Avatar
sounds like you are ok like that. it may be that the torsion bar gets weak.
Old 06-18-2015, 08:45 PM
Drag Pak's Avatar
celt69
Get someone of similar weight to you to sit in the drivers seat and then measure ride height to the fender well lip through the center of the rim.
Old 06-18-2015, 09:09 PM
Originally Posted by Drag Pak
celt69
Center of wheel to ground will affect this also, tire size, are presser etc. must be the same. I'd be checking the rest of the front suspension and the rear springs as well.
Old 06-19-2015, 03:36 AM
Archer's Avatar
celt -
With cars that old you can use the service manual specs for a door stop. Metal fatigue, distortion, blown bushings, and possible previous damage all take a toll. You're going to have set the torsion bar height by eye, then get an alignment and deal with it.
Old 06-19-2015, 11:45 AM
celt69's Avatar
celt69
I will try that, should provide some useful information. I have my battery trunk mounted, maybe contributing somewhat?
celt69's Avatar
Originally Posted by Archer
celt -
kind of what I was thinking too Archer
mopar383
12-17-2014 12:55 AM
62custom800
11-27-2014 09:31 AM
mslisaj
11-30-2012 08:47 AM
michuy
07-09-2012 03:52 PM
bruger
07-16-2010 10:14 AM
Quick Reply: front right sag on '67 Belvedere
