Low master cyl bleeding issue
Old 09-28-2016, 01:23 PM
ermracing's Avatar
Are there any special tricks for bleeding a 4 wheel drum setup with a frame mounted master cylinder? 4 of the wheel cylinders are higher than the m/c and we're having problems getting them bled. When using a vacuum bleeder the flow doesn't continue once the vacuum is turned off, even when the drain line is lower than the m/c.
Dave
Old 09-28-2016, 08:24 PM
Dave... Use a Pressure Bleeder.... That should get it handled for you....
Something like this one, with the rite lid...
http://www.nationaltoolwarehouse.com...13332C469.aspx
cudaracer
01-07-2020 12:50 PM
scotts74birds
09-14-2010 09:46 PM
buddyleewv
08-17-2010 08:23 PM
ariesfs
12-31-2008 03:14 PM
Mixmastermerrill
10-20-2008 09:22 PM
Quick Reply: Low master cyl bleeding issue
