Need alot of help
Need alot of help
I live in Colorado. I have a 69 Fury III four door with a 383 2 barrel. I need help with several things. First thing is the brakes. Is there a conversion I can do without paying Wilwood 6 grand? Is there a newer model Chrysler car/truck I can swap steering knuckles with that has the correct rotors and calipers? Also I am second owner of this car. It has 71,000 on the odometer, but it had a slight run in with a telephone pole. Does anyone have a front bumper and hood? lol Is there a transmission with an overdrive out there that will bolt right up to my 69 383? And lastly I want to find an original 69 383 4 barrel intake, and a 69 4 barrel. On a side note. I have a 69 Fury III Convertible with 62,000 original miles. It still has the biased ply tires on it. Red with black interior and top. It has the 318 motor but the production tag says it should have the 383. This car is all original, the motor has not been swapped. Has anyone ever heard of the factory making an error like that? Thanks for any help you can give me.
Check with Desert Valley Auto Parts and see if they have what you need...
http://www.dvap.com/
Oh.... And don't forget you will need the linkage to go with all the 4 barrel stuff...
As for the brake Conversion... SSBC might be able to help you with a kit...
Or check with the Hotchkis suspension.....
Welcome to the site.... Keep us post on what you find....
