Rear Shock bolts
I am restoring a 1970 Challenger and do not have the bolts which attach the rear shocks to the crossmember. Does anyone know what bolts I use and where to find them. Thanks.
You can try some socket head shoulder bolts. Fastenal is a great nut and bolt store.
if I recall correctly they are 1/2 bolts / 3/4 head approx 3" long , I would use nylock nuts , you should be able to measre the size of the hole in the shock & the width of the crossmember to confirm size .
Restoration? Are you trying to find "correct" fasteners, or just something that will work?
Found a set Online.
I finally found some online from Bill Rolik Enterprises. $12.00 for the pair, maybe a little steep but saves me time for going to the local bolt store and having to buy 10 of them for the same amount of money.
http://www.billrolikenterprises.com/...rge/1703-1.jpg |
so how close was I ?
Psycho
I'll let you know when I receive them.
