Sign in using an external account
| Register | All Albums | FAQ | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendors | TSB & Recalls |
LinkBack | Thread Tools | Search this Thread | Display Modes |
#1 (permalink) | ||
trying to adjust torsion bars
#2 (permalink) |
You need to adjust them for you vehicle's ride height...I have no idea what your cars ride height is so that is the question you need to ask. It is usually measured from some front suspension point to the ground.
__________________
1977 Dodge Aspen R/T...318 with four speed tranny....8 1/4 rear with 355 gears....20,828 original miles... ![]() 1968 Dodge Dart 440....final lift .580 roller motor...8 3/4" rear with 355 Auburn posi unit..727 tranny with reverse manual valve body what a blast to drive....
#3 (permalink) |
on most cars your lower control arms should be level with the ground.
#4 (permalink) |
#5 (permalink) |
i will try to pst some pics tomorrow of the front suspension and how it close it is to the bump stops. also where can i find new torsion bars if i have to replace them?
#6 (permalink) |
I have the stock 318 ones out of my 68 Dart that were working fine at a cheap price since your in the same area. I can't tell you for sure until tomorrow but I think they are .890/.893.
__________________
#7 (permalink) | |
Quote:
also every friday night there is a car meet off of eldridge and enclave free of charge so if you are interested or know someone that owns a classic car feel free to come and visit. |
#8 (permalink) |
By level, I meant that as a general rule in Short/Long Arm suspension the center of the pivot on the LCA would be level with the lower ball joint. This of course would only hold true if the original size tire was used and you wanted to keep the car at stock ride height for 1967.
Otherwords put it where it looks good. Trim the bumptops if needed. |
#9 (permalink) |
I measured from the top center of my front fender lip to the ground i have around 1 1/2 clearance on mine had it lower but bottomed out the bumpstop on everything. I have 25 1/4 from the ground to the top center of the wheel well lip center. On a 66 barracuda.
__________________
redneck engineerin beat to fit paint to match. ![]() 1966 barracuda 273/auto. 1973 dodge charger [project car]http://s1138.photobucket.com/albums/n522/lou3500/charger%20project/ 2001 dodge ram 1500 4x4 2011 mustang V6.6 speed manual 305 hp. 2006 volkswagon jetta 2.5 |
#10 (permalink) |
thank you everyone for your replies between work and taking care of our 3 week old i really ahven't had much time to check out where it is sitting since i adjutsed the bars. but it still acts like it is still low as when i a turning and hit a bump the drivers side bottoms out.
#11 (permalink) | |
Quote:
I installed a good set of KYB shocks and haven't had the problem since and it's been a few years now. Just a thought... |
#12 (permalink) |
My buddy put the next size larger torsion bar in his 67 barracuda and it transformed the ride. Sorry to suggest the more expensive option.
#13 (permalink) |
true it may be the more expnsive option but we are talking about a car that is 45 years old. so i am sure they will need to be replace in the near future. along with the rear springs, con arm bushings, all tie rod ends and possibly the gear box. but that is what makes working on these cars fun is tearing them down and then rebuilding them.
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| how do you adjust trunk lid? | blazer | B-Body | 0 | 09-01-2011 01:21 PM |
| How to adjust valves, 3.4 v6 ,r 1999 | Elvin | Engines, Exhaust and Fuel systems | 0 | 05-26-2011 02:37 AM |
| b-body torsion bars | timmie124 | B-Body | 7 | 04-10-2011 12:19 PM |
| how to adjust vacuum advance | gotdust | General Technical Questions | 10 | 08-10-2008 12:14 PM |
| torsion bars | thekinzuakid247 | General Technical Questions | 5 | 01-03-2008 05:38 AM |
