2006 Charger electrical problem
Hey Mopar gearheads, This is a tough one. All my idiot lights in my gauges come on momentarily and the gauge needles drop off slightly after awhile when the heater fan is on. The lights in my gauges do not dim or go out. It does not matter if my headlights are on or not. It happens only for a second or two. It is intermittent. I can drive for 5 minutes or 30 minutes before the problem occurs. I have been told the alt or perhaps a relay may be to blame. Battery & connections are solid. Anyone know anything??? Thanks
2006 Charger |
Originally Posted by dgbcharger
(Post 128160)
2006 Charger "easiest" place to start that I can think of would be try another cluster from an auto wrecker if you can find one..... Not a good option but the only thing I can think of as a place to start. Good Luck, |
