68 dodge charger volt limiter for gauge cluster
Old 05-30-2014, 03:29 PM
jj123's Avatar
was troubleshooting my gauges, all 3 arnt working, noticed that the wire going from the capacitor to the voltage limiter has fallen off. How and where does this wire connect to the voltage limiter, and should I solder it.
thanks
Attached Thumbnails 68 dodge charger volt limiter for gauge cluster-charger-gauge-cluster.jpg
Old 05-30-2014, 05:36 PM
The cap is for radio supression, and is not part of the operation of the limiter per se
Some of what I found on my Dart.........
Pins broken / loose on the PC harness connector. Solder, repair, etc
The springy contacts for the limiter were not actually making solid contact with the board traces. Solder jumpers across
Replace the IVR with a good solid state unit. If you are confident, you can build your own 5V regulator. There are many examples on the www
Loosen / tighten the gauge stud nuts several times, and consider replacing with "real" nuts.
Mock up the cluster and check the gauges. The old Mopar gauge tool had three resistors
L = 73.7 Ohms (empty)
M = 23.0 Ohms (1/2)
H = 10.2 Ohms (full)
For example, you can go to RadioShack and buy a four pack of 100 ohm, 1/2 watt resistors. Wire all 4 in parallel, which gives you 25 ohms. This you put in place of the sender to ground, leave the gauges "on" for a minute, and each gauge in turn should give you 1/2 scale
Last, the grounding for these clusters is mostly luck. Attach a ground pigtail to the board, and bolt to the column support
Old 05-30-2014, 06:31 PM
Mr.4spd's Avatar
thanks
The wire should have a 90* spade that piggy backs into the board with the limiter, it looks like it's right where it should be in the photo.
Old 05-30-2014, 09:09 PM
If that cap is shorted the limiter will blow !!!!
kabmopar69
07-17-2019 04:23 PM
labradorian70
03-29-2015 05:41 AM
74Runneer
07-29-2014 03:22 PM
koondawg_74 roadrunner
09-14-2012 02:35 PM
rcknrolfender79
12-19-2010 05:28 AM
Quick Reply: 68 dodge charger volt limiter for gauge cluster
