69 B body Tail light Dash lights Inop
Here is the lastest problem I currently have no tail lights, instrument lights, marker lights or cigarette lighter. I have read through some of the posts regarding this issue. I do have power to both sides of the 20A tail light/cig lighter fuse. My brake lights, headlghts, flashers and signals all work. Any suggestions????
Pull the fuse block and trace the power feed wire... I beet you will find that it lost its power from the source.... That wire might run threw the firewall. Check it good..
Keep us posted...
Keep us posted...
Sorry... My bad... I read it wrong....
Sounds like it might be a issue with the headlight switch or the dash panel switch.
I think it goes from the fuse to the dash panel switch first. Check to see if you have power up to that point?
AliceSML79
08-22-2014 03:28 AM
Nate Ryan
08-21-2013 02:15 PM
1966charger
04-22-2012 08:27 PM
