electric window wiring
I have a 2007 dodge Dakota, passenger window will go down but not up. Used a new motor and switch on that door. I have power to the motor on both leads. Nothing goes up but goes down perfect.I bench tested the motor with a battery and works just fine.
What should I look for? |
Same problem if you use the master switch in the drivers door?
