overcharging? how high is too high?
My chrome Powermaster 90 amp alt is running 15.10 volts
I replaced the voltage reg yesterday with the most expensive one I could find (short of the date coded resto pieces) Battery voltage 12.6 voltage coming out of bulkhead (blue wire) ignition on (not running) 11.7 I put a VM on the run feed side of the ballast 10.7 Everytime I turn on the ignition I hear my Crane PS91 ign coil click. I unglugged the ign coil then the voltage at the ballast reads 11.7 It's as if the coil is dragging voltage down. It this normal? I did a voltage drop test (from the battery lead on the str solenoid) to the ballast. getting roughly one volt drop and 1.75 when coil plugged in. Should I ditch the Crane coil for a standard can? |
I assume you rewired the alternator ???? re check your work..
Sounds like a wire problem, corroded, weak connection or burnt bulkhead connecters.
You could do a continuity test to case (ground) to be sure but sounds like other stuff. |
Here some reading for you....
http://www.madelectrical.com/electri...hreewire.shtml http://www.madelectrical.com/electri...p-gauges.shtml Just to fuel the fire.... |
The problem is not the coil or ignition. It is bad connections between the batt and ballast
Last resort but it would fix, is to trigger a relay under the hood and use the relay to feed the ignition and regulator Make sure the ground from regulator to batt is ok |
