Rear light question
My back up lights only work with the other lights off. In other words, headlights and or parking lights on, no backup lights. Is this a switch issue? If so, which one?
Do you have a good enough ground at tail lights?
I have enough that the brake lights, turn signals, and side markers work. But sometimes the left rear brake light goes out when in reverse.
As a general rule, if something electrical is acting goofy, look for a bad ground. Clean all connections and grounding points. Make sure all of the bulbs and sockets are clean and corrosion free.
Originally Posted by 1970ccc
(Post 137001)
Make sure your using the correct bulb also.. Good Grounds is a must....
