Turn Signals Defective 05' Grand Caravan (Dodge)
Hi there I have an '05 Grand Caravan and the turn signals are all messed up any help would be very much appreciated.
Issue:Signal Left turns on the right signal, signal right turns on right, with Switch in the middle position (off) the right signal turns on. With interior lights all the way up (rear interior lights on only) the turn signals shutoff. go down one notch the left turns on. anywhere in-between off and second notch the right signal turns on. My battery did end up dying and never had the same charge again. Had to boost multiple times. but alternator is good. Parts Replaced: Front Control Module (FCM), Multifunction Switch/Turn Switch, Headlight/Interior Light Switch, Bulbs Tried Fixes: Inspect remote start wiring, grounds with continuity test, cleaned contact on bulbs and sockets. I can turn all signals on with hazards though. Thanks In Advance VIDEO DIAGNOSTIC (Had to upload to YouTube) |
Faulty battery so start with.. No power drives the electrical system nuts...
