Painting tips needed
Hello gearheads, this time I need a good autobody man. I would like some tips on how to blend solid paint and clearcoat using the basecoat-clearcoat method. I am reworking some small areas on my Charger that did not come out as good as I wanted. Trying to avoid painting large sections over where the paint job came out good. Thanks dgb
dgb I would say if you are real good with a gun they offer a burning agent that you can blend its tricky but good painters can pull it off, or if you purchase a high quality paint it will match better then prep area wanting paint then color that area and into connecting panel and clear both panels as the color will blend and clear will hide
Good Luck.... As far as my opinion.... I have never been happy with that type of fix.... Keep us posted on how it turns out... :)
