need distributor for 1947 New Yorker
distributor complete for a 1947 New Yorker 8 cyc for a bud in Argentina I am going to Hershey and I don't know what serial number or make to look for or the make Also perhaps it was used on other models or years thanks much in advance
try www.aaca.org good place for the older Mopars
Was that a straight 8 ?
http://www.partsgeek.com/n8jwdpl-dod...+Radiator+Hose
From 1935 to 1940, 13 different units were used, and just about every year or model had a different unit. There were also a few confusing years in the mid-Fifties when makes again had some specific distributors, but you will find that many Prestolite distributors will interchange between years and makes. Here are a few examples:
Eight-cylinder Prestolite distributors that interchange:
E. 1941-'48 Chrysler
F. 1946-'48 Dodge D24 and Plymouth P15
G. 1949-'50 Chrysler
H. 1951-'55 Chrysler and Imperial, except 300
I. 1953-'55 Dodge cars, 1955 Plymouth and 1954-'56 Dodge trucks
J. 1958-'65 Dodge, 1958-'61 De Soto, 1961-'65 Chrysler, 1963-'65 Imperial and Plymouth with single-point distributors
K. 1958-'61 De Soto and 1962-'65 Chrysler, Dodge, and Plymouth with dual-point distributors Once Chrysler started manufacturing their own units, consistency was established across all makes, including trucks: L. 1960-'72 198 and 225 engines
M. 1962-'72 273, 318, 340 and 360 engines
N. 1961-'72 413, 426 or 440 engines (with Mopar distributor)
O. 1961-'72 361, 383 or 400 engines (with Mopar distributor) Taking this interchange one step further, you can also convert Mopar-equipped point distributors to newer electronic ignition distributors following these guidelines: L. 1960-'72 198 and 225 engines can use a distributor from a 1973-'80 225 engine.
M. 1962-'72 273, 318, 340 and 360 engines can use a 1973-'80 318 or 360 distributor.
N. 1961-'72 413, 426 or 440 engines (with Mopar distributor) can use a 1972-'78 440 distributor.
O. 1961-'72 361, 383 or 400 engines (with Mopar distributor) can use a 1972-'78 400 distributor. For the conversion, you would also have to add an electronic ignition control module and four-pole ballast resistor; however, this can be done easily and the cost involved is minimal. The efficiency of the electronics makes this conversion a popular choice among Mopar enthusiasts. This article originally appeared in the December, 2010 issue of Hemmings Motor News.
Order Backissues of Hemmings Motor News | Subscribe to Hemmings Motor News
Reader Comments
Related Stories
The 1961 Chryslers
1957-59 Chrysler 300-C, D, E
Fifties-Era Mopars
Hemmings Find of the Day - 1956 Chrysler Windsor
Hemmings Classifieds
Quick Search Links:
• Chrysler Classifieds
2001 Chrysler Prowler $29,900
1963 Chrysler 300 $23,988
1928 Chrysler $47,500
1968 Chrysler Town & Country $19,900
1964 Chrysler Imperial $16,000
2009 Chrysler Sebring $13,500
1954 Chrysler Windsor $29,500
1941 Chrysler Windsor $43,500
2007 Chrysler Crossfire $17,999
1968 Chrysler Newport $14,950
Search All Classifieds
Reader Comments
Related Stories
The 1961 Chryslers
Fifties-Era Mopars
Quick Search Links:
