uh60ip |
12-28-2014 02:59 AM |
1973 Challenger Resto-mod
6 Attachment(s)
73' Challenger resto-mod. Ground up restoration. This is not a cheap quick flip. We built this car with no expense spared. Our loss, but it must go. If a 10 would be a concours car with zero defects i'd say this car is a strong 8. The car is a total blast to drive and gets way to much attention... The 340 was bored 30 over with all new, balanced internals. It does NOT overheat even in the summer heat of Alabama. The cam is a little more than mild and sounds ridiculous. The car dyno's at around 325hp at 5050 RPM. The flow master super 10 2/12" exhaust is not what we would consider tame and quiet...The 904 3 speed was completely rebuilt as well and shifts nicely with the Hurst shifter. Power boosted Disk brakes work well however, I recommend adding rear disk brakes as well in the future. Dyno mat was installed throughout the car before interior installation. Kenwood stereo/USB/Bluetooth with Kenwood 750w amp. Paint is an 8 out of 10. The only reason its not a 10 is a few trim pieces that can be refinished. It was painted with base coat and clear then color sanded with 3000 then 2000 grit, cut, polished, and waxed. Yes, you can shave in the reflection. I could go on and on, If you have specific questions just ask. Absolutely EPIC car. $26K. kenpatrick@hotmail.com
