Mopar Forums (/forums/)
-   Vehicles for Sale (https://moparforums.com/forums/f88/)
-   -   82 Ram D150 Shortbed , 4-Speed , 318 (https://moparforums.com/forums/f88/82-ram-d150-shortbed-4-speed-318-a-15581/)
Mikeman0 08-13-2013 03:12 PM
10 Attachment(s)
I haven't had it long , I was going to finish it up in black satin and make a semi-daily toy out of it but im not into it , Fig. id post it up here before it goes on Fleabay , It is driveable but needs a carb cleaning , It is a 82 Dodge Ram 150 Shortbed 2wd , 318 V8 , All new last year == Cam and main bearings , cam and lifter set (lopey) , timing gears and chain , older Edelbrock Alum. intake , Edelbrock 600 carb. (electric choke) , water pump , Headers and duals with Flo-masters dumped , New Dodge performance orange box ignition , New brass cap and rotor , New wires , Factory 4 speed manual , Chrysler 8 1/4 limited slip rear , Power steering and brakes , manual windows and locks , New tires (5000 miles) , All lights work , Heat works , Fresh oil change , new fuel filter , super solid (only rust over drivers rear fender) Clearcoat peeling like all dodges do , $2500.00 , Located in Telford Tn 37690 , Mike 423 557 3632
Mr.Duster 08-17-2013 08:12 PM
Do you have an email?
Mikeman0 08-20-2013 07:03 AM
Just an update , Carb has been rebuilt and is running a lot better , also just installed a new radiator and thermostat , I will continue to make repairs and adjustments to it and will post up as they are done.
